I’ve been running UI5 for a long time because each time I upgrade to UI7 my switches are lost in the middle of the night. It usually takes it a few night, but each morning I wake up to blinking lights. They work fine in UI5 which is why I stayed with the old UI5 firmware. Now I want to use Alexa so I have to upgrade to UI7. Please advice. I have a house full of Intermatic CA600 devices to replace them is not an option.
Is there an option I can switch to stop removing devices in the middle of the night?
Please help? Is there a better controller for CA600 other than vera that works with Alexa? Please help.
Ok, here is the solution… its BAD but it seems to work.
Note: if you upgrade to the latest framework then your zwave firmware will be screwed this happened at 1.7.9 (i think thats it) . Even if you roll back to 1.7.8 you are still have that zwave firmware that is bad i think its 3.67. So you must follow this process.
rollback to UI5 then upgrade to 1.7.8 (never upgrade again) and you will have zwave version 3.20 and I think this works. This will give you a UI7 AND it will work with alexa and CA600.
Manually add the Alexa plugin through the vera plugin store for your controller
