Hello,
I’m about to buy a Veralite, but I have a few questions before I actually do it
I of course tried to search, found some partial answers to what I’m trying to do, but still a bit puzzled about how exactly doing it.
My goal for now is to use the Veralite to simulate a presence at home while I’m away. Maybe I’ll go further than that later, but I’ll stick to that for now. I don’t know Lua yet, but since I’m a programmer, that should not be a problem for very long ![]()
What I want to do : when I leave the house, use a switch of some sort to tell the Veralite I’m away. Then have the Vera run a script continuously or regularly (every hour for example), and have it turn on/off more or less randomly (start time and duration) some lights or a radio (probably based on the ambient luminosity, i.e. radio during day, lights during night). And stop the script when I come back.
My main problem is finding what module to use to tell the Vera I’m away or back home. I was thinking of a physical switch I would turn on or off, or some device I would keep on me (telling the Vera to do something if it can’t detect it), or use a virtual switch that would be turned on or off through the use of a small remote.
After some search, I did not find anything that would be usable in the first or second case, so I’ll probably try the third scenario.
The other issue I’m having is figuring how I turn back these objects to normal use when I’m back, and finding a way to have an immediate feedback from the Vera, telling me “I acknowledged your leaving, script starting now”, or something, if you catch my drift. But that’s probably just because I’m not yet aware of everything I’ll be able to do with it.
Am I on the right track here (remote + virtual switch), or am I missing something ? To go a little further, do we have multi-state virtual switches (for example, if I want to make a single scenario that would do different things, depending on states like : at home, at home but sleeping, away for the day, or away for a long time, like vacation) ?
Another problem is I can’t find any simple luminosity module. All I can find is multi-purpose modules (movement, light, temperatures, etc.). Is there a simple luminosity module somewhere ?
And finally, it might be a bit off-topic, but I’m thinking about using a Chumby Internet radio (to turn on or off in said scripts or scenarios) : anyone knows if this thing can accept http (or such) requests to go further than just turn on or off its power ?
Anyway, any help about what I’m trying to do here would be greatly appreciated
It’s a bit tough to find the information you need, all the more when you don’t even have the Veralite yet …
Thanks in advance.
Regards.
PS : btw, I’m french (you might have guessed by my writing, maybe
), so I might not have access to all existing zwave modules, so the simpler the solution, the better, I’d say ![]()
