VeraLite or Vera3
So I had a VeraLite but my damn cat puked on it and now it doesn’t work… I’m going to replace it, but I’m wondering if the specs the Vera3 has can sway me to purchase it instead… I have also just sold my old router, so I’m looking for a new one of those as well, can the Vera3 provide this? What performance can it provide?
Thanks for the help…
Edit: I should probably add… I only have 10 devices right now, but plan on getting more soon…
As far as I know there is no difference in the capacity of the 3 and the lite from a controller point of view. The lite just lacks the router. My preference is the lite (I have two) and then get a good dual band n router or similar that will give you much better Wi-Fi performance.
Skickat fr?n min GT-I9300 via Tapatalk
The main advantage of a Vera 3 over a Vera Lite is that it has twice the memory: 128 MB vs 64 MB. This is important if you are likely to install plugins to implement more-complex automation.
My Vera Lite ran out of memory when I had about ten plugin devices installed. It still ran but restarted quite often. It is also quite likely that new firmware versions will consume additional memory.
Vera3 is, on paper, a so-so router. Its Ethernet ports operate at 100 Mbps. With the OpenWrt administration interface disabled you can’t edit DHCP reservations. It isn’t IPv6 ready. Its Wi-Fi is 2.4 GHz only.
Buy a Vera3 for its extra RAM, by all means. But don’t buy it for its routing capability.
Also, the WiFi is nice for use as a client. Makes Vera3 quite mobile.
(And for reference, the wiki.)
