Hello! I’m very new at z-wave and I need help.
I have Veralite, lamp with z-wave and Duwi scene controller 05443.
I’ve successfully added my two z-wave devices to Verlite, created two scenes - to switch lamp on and off. When I run these scenes from Veralite everything works fine.
But when I try to add triggers to scenes there is a problem. Vera gets only two scenes ID from scene controller - 0 and 1. But my scene controller has about 12 different scenes:
Scene 1: Single Click on Upper Part of Paddle
Scene 2: Single Click on Lower Part of Paddle
Scene 3: Single Click Dim Up
Scene 4: Single Click Dim Down
Scene 5: Single Click Dim Up Stop
Scene 6: Single Click Dim Down Stop
Scene 11: Double Click on Upper Part of Paddle
Scene 12: Double Click on Lower Part of Paddle
Scene 13: Double Click Dim Up
Scene 14: Double Click Dim Down
Scene 15: Double Click Dim Up Stop
Scene 16: Double Click Dim Down Stop
I added two configuration settings to scene controller as it said in http://en.z-wave.me/docs/ZME_06443_UserManual.pdf, but it didn’t help.
Veralite only understand scene 1 (Single Click on Upper Part of Paddle), but all other are scene 0 for Veralite.
Then I tried to watch the logs of Veralite, and I figured out that my scene controller is actually sending right scene ID.
02 04/21/13 13:47:04.102 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c3ff680>
04 04/21/13 13:47:04.236 <0x2c1ff680>
02 04/21/13 13:48:34.102 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c3ff680>
04 04/21/13 13:48:34.236 <0x2c1ff680>
02 04/21/13 13:50:04.102 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c3ff680>
04 04/21/13 13:50:04.236 <0x2c1ff680>
02 04/21/13 13:51:34.102 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c3ff680>
04 04/21/13 13:51:34.266 <0x2c1ff680>
08 04/21/13 13:52:24.698 JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: LogIpRequest <0x2d3ff680>
08 04/21/13 13:52:24.699 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x2d3ff680>
08 04/21/13 13:52:24.699 JobHandler_LuaUPnP::HandleActionRequest argument action=LogIpRequest <0x2d3ff680>
08 04/21/13 13:52:24.699 JobHandler_LuaUPnP::HandleActionRequest argument IpAddress=192.168.1.34 <0x2d3ff680>
08 04/21/13 13:52:24.700 JobHandler_LuaUPnP::HandleActionRequest argument MacAddress=5c:0a:5b:9f:2f:95 <0x2d3ff680>
02 04/21/13 13:53:04.102 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c3ff680>
04 04/21/13 13:53:04.236 <0x2c1ff680>
08 04/21/13 13:53:18.557 JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: LogIpRequest <0x2ddff680>
08 04/21/13 13:53:18.558 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x2ddff680>
08 04/21/13 13:53:18.558 JobHandler_LuaUPnP::HandleActionRequest argument action=LogIpRequest <0x2ddff680>
08 04/21/13 13:53:18.558 JobHandler_LuaUPnP::HandleActionRequest argument IpAddress=192.168.1.34 <0x2ddff680>
08 04/21/13 13:53:18.558 JobHandler_LuaUPnP::HandleActionRequest argument MacAddress=5c:0a:5b:9f:2f:95 <0x2ddff680>
02 04/21/13 13:54:34.103 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c3ff680>
04 04/21/13 13:54:34.236 <0x2c1ff680>
02 04/21/13 13:56:04.102 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c3ff680>
04 04/21/13 13:56:04.266 <0x2c1ff680>
02 04/21/13 13:57:34.102 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c3ff680>
04 04/21/13 13:57:34.236 <0x2c1ff680>
02 04/21/13 13:59:04.102 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c3ff680>
04 04/21/13 13:59:04.266 <0x2c1ff680>
06 04/21/13 13:59:21.785 Device_Variable::m_szValue_set device: 4 service: urn:micasaverde-com:serviceId:SceneController1 variable: sl_SceneActivated was: 0 now: 0 #hooks: 2 upnp: 0 v:0xbaaf10/NONE duplicate:0 <0x2c1ff680>
07 04/21/13 13:59:21.786 Event::Evaluate 1 11 scene Lamp on is false repeat 0/-1 <0x2c1ff680>
07 04/21/13 13:59:21.786 Event::Evaluate 2 2 scene Lamp off is false repeat 0/-1 <0x2c1ff680>
06 04/21/13 13:59:21.786 Device_Variable::m_szValue_set device: 4 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneID was: 11 now: 11 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c1ff680>
06 04/21/13 13:59:21.787 Device_Variable::m_szValue_set device: 4 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneTime was: 1366576295 now: 1366577961 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c1ff680>
08 04/21/13 14:00:04.617 JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: LogIpRequest <0x2d3ff680>
08 04/21/13 14:00:04.617 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x2d3ff680>
08 04/21/13 14:00:04.617 JobHandler_LuaUPnP::HandleActionRequest argument action=LogIpRequest <0x2d3ff680>
08 04/21/13 14:00:04.618 JobHandler_LuaUPnP::HandleActionRequest argument IpAddress=192.168.1.34 <0x2d3ff680>
08 04/21/13 14:00:04.618 JobHandler_LuaUPnP::HandleActionRequest argument MacAddress=5c:0a:5b:9f:2f:95 <0x2d3ff680>
02 04/21/13 14:00:34.102 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c3ff680>
04 04/21/13 14:00:34.246 <0x2c1ff680>
06 04/21/13 14:01:02.735 Device_Variable::m_szValue_set device: 4 service: urn:micasaverde-com:serviceId:SceneController1 variable: sl_SceneActivated was: 0 now: 0 #hooks: 2 upnp: 0 v:0xbaaf10/NONE duplicate:0 <0x2c1ff680>
07 04/21/13 14:01:02.736 Event::Evaluate 1 11 scene Lamp on is false repeat 0/-1 <0x2c1ff680>
07 04/21/13 14:01:02.736 Event::Evaluate 2 2 scene Lamp off is false repeat 0/-1 <0x2c1ff680>
06 04/21/13 14:01:02.736 Device_Variable::m_szValue_set device: 4 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneID was: 11 now: 14 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c1ff680>
06 04/21/13 14:01:02.737 Device_Variable::m_szValue_set device: 4 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneTime was: 1366577961 now: 1366578062 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c1ff680>
06 04/21/13 14:01:03.725 Device_Variable::m_szValue_set device: 4 service: urn:micasaverde-com:serviceId:SceneController1 variable: sl_SceneActivated was: 0 now: 0 #hooks: 2 upnp: 0 v:0xbaaf10/NONE duplicate:0 <0x2c1ff680>
07 04/21/13 14:01:03.726 Event::Evaluate 1 11 scene Lamp on is false repeat 0/-1 <0x2c1ff680>
07 04/21/13 14:01:03.726 Event::Evaluate 2 2 scene Lamp off is false repeat 0/-1 <0x2c1ff680>
06 04/21/13 14:01:03.726 Device_Variable::m_szValue_set device: 4 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneID was: 14 now: 16 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c1ff680>
06 04/21/13 14:01:03.727 Device_Variable::m_szValue_set device: 4 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneTime was: 1366578062 now: 1366578063 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c1ff680>
06 04/21/13 14:01:05.775 Device_Variable::m_szValue_set device: 4 service: urn:micasaverde-com:serviceId:SceneController1 variable: sl_SceneActivated was: 0 now: 0 #hooks: 2 upnp: 0 v:0xbaaf10/NONE duplicate:0 <0x2c1ff680>
07 04/21/13 14:01:05.776 Event::Evaluate 1 11 scene Lamp on is false repeat 0/-1 <0x2c1ff680>
07 04/21/13 14:01:05.776 Event::Evaluate 2 2 scene Lamp off is false repeat 0/-1 <0x2c1ff680>
06 04/21/13 14:01:05.776 Device_Variable::m_szValue_set device: 4 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneID was: 16 now: 12 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c1ff680>
06 04/21/13 14:01:05.777 Device_Variable::m_szValue_set device: 4 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneTime was: 1366578063 now: 1366578065 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c1ff680>
I can see in logs that LastSceneID is changing through the time to the right button combination that I use one my scene controller. But triggers for these scenes doesn’t work.
Maybe it is somehow connected with sl_SceneActivated variable in logs, I don’t know.
Does anyone have any ideas what can I do?
