Went to work on a Vera issue with tech support and noted that web browser and SSH never connect (they just hang indefinitely). Vera website reports it can’t connect.
I can ping the Vera IP and it responds every time with a Sercomm MAC address (must be the HW manufacturer).
I can’t get home to reboot this thing, nor should I have to. Any advice? I have USB logging turned on.
[quote=“solarshine, post:1, topic:187181”]Greetings all,
I can’t get home to reboot this thing, nor should I have to. Any advice? I have USB logging turned on.[/quote]
Can you VPN or remote to a computer on the LAN and try to get in locally?
I have had remote issues that I could VPN and connect locally to, give it a reboot. Then retry. If not you need to reboot locally.
[quote=“solarshine, post:3, topic:187181”]Yea, I did try by remotely controlling a PC on the LAN. VeraLite doesn’t refuse connections, it is just silent… HTTP and SSH.
About to ask the Wifeypooh to look at the status lights. I can already see the eyeball rolling…[/quote]
Ok then have her pull the plug and replug while shes there.
