My VeraLite suddenly got stuck with the message: “ZWave : Configuring Z-Wave devices in your system.” at the top of the webpage.
Tried resetting Z-Wave network, and hard resetting the Vera. Still the same message all the time. Anybody?
[quote=“NickStrong, post:1, topic:184381”]My VeraLite suddenly got stuck with the message: “ZWave : Configuring Z-Wave devices in your system.” at the top of the webpage.
Tried resetting Z-Wave network, and hard resetting the Vera. Still the same message all the time. Anybody?[/quote]
Give it time? How many Zwave devices do you have? Patience is a hard earned virtue when dealing with Vera LOL.
Right now I have 0, since i reset everything. Cant add or do anything right now since the messeage is there.
Downgraded to UI5, still same problem…
Did you try holding the button for 10 seconds? If yes, you may have to contact support and see if they have a way of reviving your Vera.
Didnt work, I’ve contacted Vera support. Hope it helps
I used this once when I updated to UI7 and then couldn’t get back ![]()
Flashed the F/W and reloaded from my back ups and was up and running no problem. Might help you recover your’s.
http://wiki.micasaverde.com/index.php/Firmware_Flash_VeraLite
Thanks for all the help. Vera support helped me and got me back up an running again. But when I got all my devices added again the same problem came up again. Maybe I’ll try the Firmware flash linked to.
Most likley ill go to HomeSeer or another solution, Vera doesnt look good atm.
Did this start happening when you changed anything on your zwave network (add or deleted and devices)? Maybe try adding them one at a time and see if one of your devices it causing the issue? (assuming you are adding them all from zwave backup a file) My VL has been really rock solid (UI5) and I travel a ton so that is important when I am away for it to function properly and reliably.
Maybe there is a damaged board, cold solder joint, a loose connection, etc; something specific to your device.
Defiantly I would flash the firmware and see where that gets you to (can’t hurt right if you are unable to use the device). Just throwing some ideas out there for you. GL!
[quote=“rayp, post:7, topic:184381”]I used this once when I updated to UI7 and then couldn’t get back ![]()
http://wiki.micasaverde.com/index.php/Firmware_Flash_VeraLite[/quote]
just had this happen to me on veraedge ui7, did a restore from backup and fixed it, did not have to check restore zwave network
