VeraEdge Wi-Fi Question
Can VeraEdge be used to access the internet through Wi-Fi using encryption WPA2 (PSK) with a passkey like you can with Vera 2?
Thanks,
Reed
Hi Reed,
Make sure you have the latest firmware installed and this will work with the VeraEdge same as it did with the Vera 2.
This can be done from Settins->Net&Wifi with the following “limitations”
Vera Edge Update - wifi client setup will not work if:
  • Secure Vera is enabled
  • user is connected over relay
  • wifi ssid is hidden
  • wifi router has dhcp disabled
Thanks!
Reed
