VeraAlertsLANSend:LAN: Error Connection
Hi there. I have been using a Vera-Alerts-Mobil profile for a while and I’m now trying to get the LAN profile working. Whenever I send a test alert though, I get the “Error Connection” message. Full log output below. The device is connected to WiFi and the IP address entered in the VA LAN profile is correct. I can also ping it from a PC no prob.
I’ve tried different ports too and rebooted the device a bunch of times. The Vera-Alerts-Mobil profile still works great but as this particular device never leaves the home, I was hoping to use a LAN profile to make comms more efficient.
Any help appreciated.
Logfile output:
08 03/16/15 15:47:00.410 JobHandler_LuaUPnP::HandleActionRequest device: 75 service: urn:richardgreen:serviceId:VeraAlert1 action: SendAlert <0x2f0d3680>
08 03/16/15 15:47:00.410 JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=75 <0x2f0d3680>
08 03/16/15 15:47:00.410 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:richardgreen:serviceId:VeraAlert1 <0x2f0d3680>
08 03/16/15 15:47:00.410 JobHandler_LuaUPnP::HandleActionRequest argument action=SendAlert <0x2f0d3680>
08 03/16/15 15:47:00.411 JobHandler_LuaUPnP::HandleActionRequest argument Message=test <0x2f0d3680>
08 03/16/15 15:47:00.411 JobHandler_LuaUPnP::HandleActionRequest argument Recipients=Vera-Alerts-LAN <0x2f0d3680>
08 03/16/15 15:47:00.411 JobHandler_LuaUPnP::HandleActionRequest argument rand=0.7244245300535113 <0x2f0d3680>
50 03/16/15 15:47:00.414 luup_log:75: VeraAlert:75:SendAlert:Msg:test <0x2b336000>
50 03/16/15 15:47:00.414 luup_log:75: VeraAlert:75:ExpandRecipients:Checking:Vera-Alerts-LAN <0x2b336000>
50 03/16/15 15:47:00.415 luup_log:75: VeraAlert:75:ExpandRecipients:Adding Requested Profile <0x2b336000>
50 03/16/15 15:47:00.417 luup_log:75: VeraAlert:75:SendAlert:Sending to:Vera-Alerts-LAN <0x2b336000>
50 03/16/15 15:47:00.417 luup_log:75: VeraAlert:75:VeraAlertsLANSend:To:192.168.1.2:2048 <0x2b336000>
50 03/16/15 15:47:00.747 luup_log:75: VeraAlert:75:VeraAlertsLANSend:LAN: Error Connection Target:192.168.1.2:2048 Msg:test <0x2b336000>
50 03/16/15 15:47:00.774 luup_log:75: VeraAlert:75:SendAlert:Memory:362105 <0x2b336000>
04 03/16/15 15:47:00.775 <0x2b336000>
The protocol is quite simple … sounds like you have the wrong IP address.
You can verify the IP address from the “Settings” tab of the Vera Alert Mobil App on your android phone … Scroll down to where it allows you to enter the port.
It will show the current IP address. Unless you have reserved an IP address on your router … this address will likely change every time you connect with WIFI.
Deleted
[quote=“RichardTSchaefer, post:2, topic:186451”]The protocol is quite simple … sounds like you have the wrong IP address.
It will show the current IP address. Unless you have reserved an IP address on your router … this address will likely change every time you connect with WIFI.[/quote]
I got it working. It didn’t occur to me that where it allows you to enter a port, it was showing my IP as 0.0.0.0. I had to unregister for the right IP address to appear. Works like a charm now.
Thanks for the tip!
