Basically, it seems to run fine as long as I don’t touch the phone. But, if I go to the home screen, and then go back into the VeraAlerts app, the phone is really laggy, almost like the memory is exhausted. And then VeraAlerts crashes.
Do you use it only for TTS ?
How often do you open the Application to look at messages ?
Anything unique about the messages ?
Typical size of message ?
If you are using LAN I do not need a VeraID.
[quote=“RichardTSchaefer, post:4, topic:179981”]Do you use it only for TTS ?
If you are using LAN I do not need a VeraID.[/quote]
Yes, only for TTS. Usually the app is left open and I’m not at the home screen, but rather the in the app. The problem occurs when I switch back to the home screen to do something else, and I switch back to the app. Nothing is terribly unique about the messages, other than they all have an alert tone played before the TTS. The size of each message is typically small, such as “Front door opened.” During the day, it also speaks the time every half hour (“ The current time is 2:30pm.”) But every morning when I disarm the alarm, it speaks the current weather and the forecast for the day. The weather alert is probably 200+ characters
Removing OLD entries is only done when you ENTER the page that lists the alerts.
Can you check the FREE memory on your Mobile …
I may have to add a periodic clean to purge messages.
I’ve had this crash a couple more times. It’s currently broken again. I pressed the button that sent the crash report. Richard, did you get a chance to take a look at it?
By run … do you mean the window that shows all the messages ?
Or do you mean that it’s listening on the LAN port all the time ?
I need to review when I do the cleanup of old data … I think it’s when I open the window to display the entries. So if you do not do that … I guess it can fill up the database/memory with messages.
I might have to revisit that.
