vera3 web acess via Ipad
Hello !
I can acess my vera3 remotely logging in micasaverde.com (from my computer on the work) . I can control the lights and all functions…
using my ipad I have SQconnectHD installed and runs very well. even remotely.
but when I’m going to the safari browser and trying logging in micasaverde and acess the my vera3 not runs !
a yellow message appears on the screen of the ipad.
is a problem to acess vera3 from ipad ?
thanks !!!
Try cpui5.mios.com
Brientim, thank for help…
even very slow but I get connected via ipad…using your tip.
is normal the access via micasaverde redirects runs slow ?
I’m in Brazil.
thanks !!!
There’s a free app for iPhone called VeraMobile that works pretty good. It may work on iPad as well. A Safari connect on an iPhone just doesn’t have enough real estate for viewing. :slight_smile:
The other link you should try http://micasaverde.com/phone/
I use automator.app - it’s really good :slight_smile:
I concur and both my wife and I use automator.app - it’s really good with both the iPhone and iPad.
I bought automator.app and really runs very fast even out of my home ( in the work).
but when I click in create automator device an error occurs…
what this function does ?
what app allows add device to my network ?
thanks for all !
[quote=“Piwtorak, post:8, topic:171954”]but when I click in create automator device an error occurs…
what this function does ?[/quote]
When you first open the app on your iPad, you should click on step 1 Plug In files. This install this software on your Vera. Give it 5 minutes or so to complete the install and restart your Vera. If you at home you can watch this happen on your PC.
Then click the create Automator device. This creates the device on you system that enable you to record on iPhone, iPad unique device ID (or multiples) which is used to enable your Vera to send push notifications directly to your phone or iPad Vera a scene. You can add multiple to enable different messages to be sent to either one or more different receiptients.
I’m am unsure what you mean by this question. However if you add an extra device to you Vera it will show up in Automator next time you open it on you iPad… If you mean how do you add a device remotely, it is through the web interface you logged onto using cpui5.mios.com but this is best done from home.
Good reference for Automator.app and any follow up question should posted in its thread at
http://forum.mios.com/index.php?board=18.0
Also they hab FAQ on it site se automatorapp.com
Great ! is clear for me now…
I will try !!! thanks !
