vera3 Edit Devise Thermostat Schedule - does not seem to affect CT100
Hello,
I am a complete newbe at this. I recently bought and installed a vera3 as well as the 2Gig CT100 Thermostat. It included just fine, however I cannot get the vera3 to actually control the thermostat. There is a schedule on the Edit Device page when I select settings for the thermostat from the standard vera home page (not the advanced settings). You can edit the schedule, which I have done, however, it does not seem to actually have any affect on the CT100 thermostat.
Does this schedule not actually do anything? Do I need to create a scene to trigger it to work?
Sorry, this is probably a very basic question.
Mark
Someone gave me this a long time ago, and I am still grateful.
I created a scene with a schedule to run every 60 minutes. You will find good and bad in how high or low you set that time.
Then in the luup code add the following. You will need to change the device code (30 in this example) to the device code of your ct100. the temperatures separated by commas start with sunday. the times are seconds, so you might have to calculate based upon the standard clock time that you want. so every 60 minutes this scene gets executed and the temperature for that time range is sent to the setpoint of your thermostat. the downside is that if you manually override your setpoint, then sometime in the next 60 minutes it will get reset to your schedule. for vacation, I disable this scene, put the thermostat on hold temp, and turn it to an energy friendly number.
I wish I could give credit to the person that gave me this, but I haven’t been able to find it again in the forum.
local temps_Heat = { {64, 64, 64, 64, 64, 64, 64, startTime=3600}, – 1:00AM
{65, 68, 68, 68, 68, 68, 65, startTime=23400}, – 6:30AM
{65, 65, 65, 65, 65, 65, 65, startTime=32400}, – 9:00AM
{65, 65, 65, 65, 65, 65, 65, startTime=46800}, – 1:00PM
{65, 66, 66, 66, 66, 66, 65, startTime=59400}, – 4:30PM
{65, 65, 65, 65, 65, 65, 65, startTime=82800} – 11:00PM
local temps_Cool = { {75, 75, 75, 75, 75, 75, 75, startTime=3600}, – 1:00AM
{74, 74, 74, 74, 74, 74, 74, startTime=23400}, – 6:30AM
{74, 74, 74, 74, 74, 74, 74, startTime=28800}, – 8:00AM
{76, 76, 76, 76, 76, 76, 76, startTime=46800}, – 1:00PM
{74, 74, 74, 74, 74, 74, 74, startTime=63000}, – 5:00PM
{76, 76, 76, 76, 76, 76, 76, startTime=79200} – 10:00PM
local thermostatDeviceNumber = 30
local t = os.date(‘*t’)
local current_second = t.hour * 3600 + t.min * 60 + t.sec
local current_day = t.wday
function applyTemp( serviceId, tempsTable )
for i,temps in ipairs(tempsTable) do
local startTime = temps.startTime
local endTime = current_second + (3600 * 24)
if (tempsTable[i+1]) then
  endTime = tempsTable[i+1].startTime
if (endTime > current_second) then
  if (startTime <= current_second) then
    luup.log("Settint " .. serviceId .. " temp to " .. temps[current_day])
    luup.call_action(serviceId, "SetCurrentSetpoint", {NewCurrentSetpoint = temps[current_day]}, thermostatDeviceNumber)
applyTemp( “urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”, temps_Heat )
applyTemp( “urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”, temps_Cool )
return true
Thank you,
I just lifted that code for my new Honeywell TH8320. This is Day 1 of the Z-wave journey so I am learning as I go.
[quote=“karana, post:3, topic:180109”]Thank you,
I just lifted that code for my new Honeywell TH8320. This is Day 1 of the Z-wave journey so I am learning as I go.[/quote]
So, I for some reason I am seeing that the schedule is not executing consistently. I tried to run every hour and then changed to every 30 mins but the schedule last ran at 6:00 AM and its currently 7:51PM.
Did you change this line to represent the device number for your thermostat?
local thermostatDeviceNumber = 30 my thermostat device number is 30, yours probably isn’t.
