I have one Vera2 unit controlling 2 other Vera2 units. I need to disassociate them now and have them run independently.
How do I accomplish this?
Thanks.
Thanks.
You should be able to just select the Vera device in the Vera web interface and click on the trash can. When you bridged the vera units, it should have created a device that represents that vera unit.
I did see those icons. I just didn’t realize it was that easy!
Thanks!
The trash icon will work for the bridged vera units. If you want to remove a z-wave device from Vera, you will need to follow the excluding process. The trashcan icon will also work for removing 3rd party plugins as well.
