Hi everyone,
I am still a newbie in this world but I see a lot of good potential. I bought a couple of devices to test it and now I am at the point that I have a couple of question regarding the project I would like to complete. I can understand the basic of this system but since I bought a 3in1 motion sensor and a magnetic door sensor, I feel like I was a real dummy !
Here’s the project…
The devices:
-A vera2 with the last firmware
-A 3in1 homeseer hsm100 motion/temp/sun sensor
-A home manageable magnetic door sensor (probably made from intermatic)
-Leviton vizia rf+ 600w scene capable dimmer
-Appliance module (ON/OFF) from wayne dalton
What I want:
Protect the cottage and the shed from intrusion and have the benefits of home automation.
The Shed:
In the shed, there is a magnetic door sensor screwed on the principal door and a leviton vizia rf for the lights.
I would like that when the sensor is not armed, when I open the door, the lights open immediatly, and when I close it, light stay on for 15 seconds and then turn off.
When the sensor is armed, if this same door open, it will not turn on the light, but it will give a 10 second of inactivity before starting the appliance module, with a big siren plugged in it. If possible, it could be great that during the same 10 seconds, lights flash on and off every second for exemple…!
The Cottage:
Approximatly the same project as the shed, but a bit more complicated.
With a motion detector hsm100, I would like that if the sensor is armed, and there is intrusion, it do the same thing as the shed. It wait 10 second before starting the appliance module for the siren and if possible, flash the light before siren go on.
But when it is not armed, (“bypass” I suppose), I would like that if all lights are OFF (only during the night), I would like that if motion is detected, light will turn on on a 40% dim for exemple and turn off after 2 minutes of inactivity…
So when people are in the cottage, they have the light that turn on if they need a glass of water at 3 am, and the cottage is protected by an alarm if there is intrusion when there are away.
Where I am now:
I am ok with the light that go on when I open the shed but they dont go off 15 seconds after I closed the door.
I dont know how to set the 3in1 motion detector to have what I want. I read a lot on this forum and didnt find the good solution…I think I will need a step to step to configure that thing.
I dont understand why but one of the vizia rf sent me those feedback:
1- Device failed to configure
2 - Transmit failed with code: 1
One time, I didnt know why, but the message disapear and everything was perfect but after a reboot of the vera, the same problem came back
and another vizia in the cotage was perfect and suddenly gave me the same error message…
I know there is a lot of stuff in this and I hope that my problem seems really easy to complete !!
thanks a lot
