Is it possible to use both Vera2 and Homeseer in the same zwave network.
I use Vera2 ui4 and HS 2.5 with Aeon-labs v2 usb zwave stick.
I cannot find the option to add a controller in Vera2 ui4.
Regards,
Frank
Regards,
Frank
If the question you’re asking is how to get the Aeon Labs stick to work with Vera 2 then set the device port to “/dev/usb/tts/0”.
Well, no, I think he is asking “Is it possible to use both Vera2 and Homeseer in the same zwave network.”
I am trying to do the same thing, since each has strengths, and neither is perfect. I haven’t tried too much, but I am trying to decide which should be the Master controller.
Thanks, Rick
Any update on this? I’m looking to gain home automation control inside of Windows Media Center. Saw this today:
I figure I’ll throw a USB Z-wave stick in my home server to allow me to interact with my devices via MC but keep all the scenes/scripting on the Vera.
