Vera with Danfoss Living Connect thermostat
I think the delay you are talking about is related to when the thermostat is starting to act on a changed setpoint. What I am strugling with right now is to get the changed setpoint sent to the thermostat.
I have discussed the delay issue with a guy from Danfoss and it should be related to the PID regulator in the thermostat. If that is the case I think it will vary depending on the actual situation. However, the guy was not from the technical department, so I will try to get through to a technical guy later on when I have got some more experience with the units.
I am changing setpoints via a scheduled scene so we will see what happens.
Guys,
This is just a suggestion and you can tell me to @££& off, but could we run conversations/issues around that new Living Connect unit under the other thread, which is specifically titled for the new device. I would hate for anything to get lost as this thread started off talking about the older version.
http://forum.micasaverde.com/index.php/topic,12289.0.html
FYI - I hope to get my new TRVs soon too, so I can then start to contribute.
@Parkerc: I agree, however this issue that Floris is talking about is the issue with the old/current valves… and probably with the new ones ass well but we dont know yet…
@Floris:see this post in the other topic towhich Parkerc is referring: http://forum.micasaverde.com/index.php/topic,12289.msg90465.html#msg90465
I see what you mean Parkerc… the issues are mixing up…
Maybe its better to start a summarizing topic when we have more intell on the new valves or something…
Did any of you guys needed to buy additional adapters by the way?
The valves are M30 I think and my current valves are 1/2"… is there a standard adapter I can use?
