Since there’s a lot of talk about dissatisfaction with Vera and discussion about Homeseer, I thought I’d share some thoughts and experiences. Of course, this is all my opinion - but I’ve had a Vera Lite for a few years and also have a Hometroller Zee S2. I was pondering the differences/benefits a few months ago, so hopefully this helps someone.
The Zee S2 is basically a raspberry pi 2 running the Linux version of Homeseer. So it has some decent power, memory, power consumption, and expandability.
Device pairing/removing: The vera was substantially easier. Its battery let me carry it to devices that needed to be within a meter of the vera during pairing. The Zee needed to be plugged in and connected to my lan with a cable to do the same thing (which required some creative solutions). No contest here.
Power Usage: Both controllers sip power (probably less than 10watts). Homeseer can be a real power hog if you buy the software and install it on an old computer.
Price: The Vera lite is only about $90 and the plus is $150. The Zee S2 is on sale for $170. I’ll have to buy the Tasker plugin ($40) and the Imperihome plugin ($40) for a total of $250. The tasker plugin for vera (autovera) is free and imperihome works without any plugins.
Automation: Homeseer Zee S2 wins here. The vera has extremely basic scene capabilities. I don’t think it can even do a decent “if” condition without a plugin. You can buy the PLEG plugin to get some better logic control, but plugins can be a gamble on low memory devices like the vera lite. The Zee’s logic system is very robust.
I’ll keep both (one for home and one for office). The vera lite was just fine for my small 20-device system. I think it does everything that it’s supposed to for well under $100. It had an annoying habit of adding a dozen or so phantom devices every 6 months, but it was stable and never crashed. It would occasionally lose communication with some of my old CA600 switches, but I hear they are garbage so I’ll split the blame between them and the vera. It’s definitely not a good choice for large systems. It should be obvious, but why would someone use a $100 brain to control several thousand dollars worth of switches and devices?
The Zee’s interface is rich in features (possibly too rich) and more responsive than the Vera’s UI7 - even though homeseer is still stuck in the 90’s from a design standpoint. The vera needed some finagling and some plugins to get my Aeon power meter and Monoprice devices to work properly. All the devices worked correctly on the Zee without any additional setup. They also seem to be a little more responsive on the Zee. The zee feels a lot more like a piece of software that’s slapped onto some hardware than the vera (that’s what it is), so it can be more intimidating than the Vera’s more modern, but simple, interface.
I didn’t have many issues with my appropriately-sized system, but I’m certain that my Lite couldn’t handle many more devices. Time will tell of the Zee will do the same.
I’m open to any questions…
