Vera Virtual Keypad for AD2USB
Hi All
Still loving this plugin and how much it enables me with what I want to do!
Is there any way to communicate with the AD2USB via the Vera to use it as a virtual keypad? I’m regularly tinkering with the different programmable zone types and I’m getting sore legs stood up at the wall keypad for hours at a time lol
I was wondering exactly the same thing! Anybody know? I’ve been searching and found zilch
im suprised this has not discussed more?
what a great feature that is lacking/missing.
Count Me In!!
Not exactly a virtual keypad, but you can use steps described in this post to gain telnet access to ad2usb and use it to program your system:
http://forum.micasaverde.com/index.php/topic,7266.msg71129/topicseen.html#msg71129
1. Connect to Vera via SSH:
ssh root@Your.Vera.IP.Address
  1. Stop the Luup stack: (command may be different on UI4)
    /usr/bin/Stop_cmh.sh
  2. Start ser2net to connect to the AD2USB and listen on TCP port 4444 in telnet mode
    ser2net -C “4444:telnet:0:/dev/ttyUSB0:115200 1STOPBIT NONE”
  3. Telnet to port 4444 (i.e. connect to ser2net / AD2USB):
    telnet localhost 4444
  4. Configure AD2USB with the “!” command. When done press “Ctrl-]” and then “e” to exit telnet
  5. Reboot:
    reboot
Instead of pressing “!” to change ad2usb settings, just start making keyed entries as you would on your panel. I.e. key in your installer code + 800 and you will get into the programing mode.
A bit ugly hack since you are basically shutting down the automation, but it does the job.
I have a similar problem. Ademco_Vista Alarm Panel indicates “missing Port”, and when I click on ‘Clear’ I get the error message “Device Communication Failure”. But when I access Vera 3 via SSH and start telnet, it connects to the alarm system. Any suggestions before Alzheimer completely engulfs me?
When did you purchase your AD2USB? Recent batches have a new USB chip and require some steps on the Vera to be recognized as a serial port. Please see alarmdecoder.com » View topic - Veralite shows serial port as Not Available if this is your issue.
