I guess I was naive… what I got message about was new IOS app, MMS Vera… also stating you would need latest firmware for it to work. I, not knowing it’s beta testing of UI6 simply went to micasaverde.com which forwarded me to getvera.com. clicked on support and update firmware and next thing I know I got UI6. I’m going to edit my previous posts as to hope to deter others from making my same mistake. kicks self and walks away with head down…
PLEG Version 5.9 now supports UI6
I can’t edit the actions in PLEG version 5.92 with UI6
My scheduled events are no longer triggering actions. I also noticed that when I print the report it says PLC Version: 5.91 but 5.92 is installed. I’ve attached copy of the report. The triggers for my switches appear to still work but the schedules are not triggering. I even tried the “Do It Now” but actions do not occur.
Auto-update 5.93
It works again! I can edit the actions.
I tried to turn debugging on but keep getting following error message. “ERROR:Module not found:cgi-bin” I tried both Vera Logging and standalone.
Anyone with UI6 having problems with scheduled triggers? PLEG scheduled triggers were working prior to 5.93 but I couldn’t edit triggers… now I can edit the triggers and scehduled triggers but the scheduled ones are not triggering the actions.
Also noticed once auto update installed 5.93 for Core & Event Generator I ended up with two Program Logic Core devices. Not sure if this causes a problem or not so I uninstalled and reinstalled core. I only have one core device now. Timer switch states it’s version 5.92.
5.91, 5.92, 5.93 are all the same code … just packaged in the App store differently.
They are all compatible with each other.
There should ONLY be one core.
Updated to 6.0, purchased licensed, verified, and my PLEG schedules are still not triggering the actions. I don’t know what I did to make them stop working when I went from 5.91 to 5.93. I’ve tried deleted and recreated my scheduled triggers but still not triggering the actions. Also tried clicking the “Do It Now” button but that doesn’t trigger either.
Please attach a status report.
Attached. Is it because all my conditions for the schedules are reading “True” ? If you need rest of pages let me know. I couldn’t upload all because forum said file too large.
BTW, the Debugging Log now is working. Before I was getting an error message.
for conditions that you expect to repeat which have schedules with a start time and no end, you need to add an underscore “_” in front of their name or in the new version you have, check the repeat box.
The attached example is one of a few you have that way here.
Edit the condition and check the repeat box.
Thanks, That fixed it. My apologies I must have missed having to do that from one version to the next.
