My Veralite G seems to be turning off every hour or so. The lights on the unit turn off and I have to unplug it and plug it back in to have it turn back on. Anyone know how to solve this?
Thank you for your help.
I suspect your power supply is failing.
Try using another power supply that provides 12VDC and a minimum of 1 Amp watt output.
I think Z-Waver meant 1 ampere not 1 watt :
I’m new to all this (I’m already hooked, I have iBeacons opening my garage when I drive up), so where might I purchase a new power cable? Is it available at a sore like RadioShack?
You are correct. I have updated my post.
Thank you.
Get it while you can. RadioShack has filed for
protection.
