Vera Thinks Everything is a Scene Controller
I have excluded/included/rebooted several lamp modules and Vera keeps adding them as scene controllers. I exclude them and reboot and the scene controller is still there. So I delete the device through HTTP and reboot again. The device is gone. Include a lamp module, and it shows up as a scene controller again. I’ve even tried changing the device file to D_BinaryLight1.xml, but this doesn’t seem to solve the problem.
[I have also recently excluded an Intermatic handheld remote, but I can’t think of a reason why that would be an issue here.]
Any ideas would be most appreciated. Thanks.
Factory reset?
Roll back to last working backup?
Are you doing just a simple include - from software or Vera buttons (which sort of Vera)?
…or have you been playing with any Luup .xml or .lua files?
I hope that’s not necessary, but I’ve been considering whether that might not be ultimately what’s needed.
I'd be happy to give that a go, but I wouldn't know what backup would be the right one to use. Vera is working--it runs all scenes when it's supposed to. I can't remember when the last time was that I included a new device; it's been quite a while.
Actually, I've tried both. (Vera 2)
...or have you been playing with any Luup .xml or .lua files?
I haven't edited any of the files manually.
I’m stumped. I may just go the reset route. It would be a shame to have to do that, though.
When you include a lamp module and it tells you it’s a scene controller, what does that Advanced tab tell you are the .xml device file types? Presumably, for some reason, controllers. If you change these to the correct strings for a lamp file (presumably you have SOME correct, somewhere), and reload, then what happens?
It was a controller file, yes. I tried changing the device file to D_BinaryLight1.xml and Vera shows the device without on or off buttons. But I just noticed that the device type (upnp schemas) was still set to a scene controller type. I changed that the binary light as well, and now it has buttons, but still no joy.
…and you restarted to check it stayed that way?
Looking like a reset…
I’ve run out of trouble-shooting ideas. You might hope a real expert turns up. Good luck!
I’ve run out of trouble-shooting ideas. You might hope a real expert turns up. Good luck![/quote]
Indeed I did. Both restarts and reboots. Still no joy.
I think a fresh start might be the way to go. I’m just not looking forward to all the work that going to be required to rebuild the network, scenes, and custom Lua.
Thanks for trying!
you could try to make a troubleshooting ticket and ask MCV techsupport to help you out. they probably can fix this as it is something in the scenecontroller device messed up.
You know, I probably should. But there is a bonus of cleaning out years of ghosts with a reset.
I’ll probably check with MCV because I am LAZY. :slight_smile:
perhaps not a bad idea. i didnt reset to get rid of the ghosts as i like them too much and am lazy too. so far my vera does ok and has no problem with these ghosts and neither do i :smiley:
After taking some time to run through some iterations, I think that adding the lamp modules had little to do with this problem.
I have excluded the new modules from Vera, however, the phantom scene controller remains. I can delete the phantom scene controller through the UI or through an http call, but as soon as I do a power-off reboot, the phantom device returns.
This is not Vera’s own internal scene controller you’re trying to delete, is it? What is the device number?
Nope. The assigned device number has been in the 68-70 range. It’s presently 70 (node ID 21).
Have been working on this issue with MCV. MCV are suggesting that my Vera doesn’t think that it’s the primary controller (even though the UI reports PRI:YES). Right now, they are suggesting that I reset the Z-Wave chip and try to re-add my devices, or reset the Z-Wave chip and try to restore from backup.
I’m not thrilled with either of these choices and may resort to a full factory reset instead.
In that light, have they had you try the [tt]Hack to convert 2.78 to 3.20[/tt] option on the [tt]Z-Wave Settings > Advanced[/tt] tab? (As it seems to manipulate the Z-Wave controller role.) Assuming you currently are on 3.20.
In that light, have they had you try the [tt]Hack to convert 2.78 to 3.20[/tt] option on the [tt]Z-Wave Settings > Advanced[/tt] tab? (As it seems to manipulate the Z-Wave controller role.) Assuming you currently are on 3.20.[/quote]
Yes, tried to no avail.
I think a factory reset is going to be required. If that doesn’t solve the problem, we think it might be a hardware failure.
Updated.
Neither I nor MCV can talk reliably to the Z-Wave chip on my Vera 2. I have even cracked the case, unplugged and reinserted the chip physically. A factory reset and Z-Wave reset will not clear the Z-Wave table and no devices can be included or excluded. Ironically, Vera can still operate devices that had already been included.
I think that this is either a hardware failure or tied to a bad Sigma bug.
