I have a Dresden fls-pp lp Zigbee ZLL ballast running the LED strip behind my TV.
And an original gen1 Philips Hue strip behind my AV cabinet below the TV.
To get solid colours looking the same shade to the eye, I had to use different Hue values.
Looking at code, you really just set the color, not saturation.
AFAIK SetColor should do the trick for you, since it accepts a raw color.
EDIT: anyway, saturation can be set with brightness. AltHue use standard device files/actions, so it’s easier and can be mixed with any native z-wave enabled RGB lights.
I can use newColorRGBTarget with the AltHue plugin and a Vera scene
This works and changes the LED strip to Blue.
However if I set both the Dresden and the Philips Hue strips to blue using RGB 0,0,255 they are different shades of blue, so I am back to my original problem.
Which is why with the original Philips Hue 2 plugin for Vera I was using different HUE values to set blue on each strip, so to the eye they looked like the same colour blue.
This difference in colour shades is worse and more noticeable for colours like Orange and Purple
