I added some new devices to my Vera a Few days ago (Fibaro Motion Sensor V2.6) and also needed to Upgrade to Firmware 1.5.6.72
I noticed that Sometimes i can’t use my Phone to Fetch the Vera (Using the Vera Mobile App) .
Sometimes i need to turn the App Off and On a few times until Vera is Initialized.
I also started to see that All the Leds are Lighting (not blinking) on the Vera (Green , Orange , Blue and… RED) . even if i’m turning Off and ON the Power - After Vera is finished to Load - the Leds are lighting.
I thougt it’s battery Problem so i replaced them , but still the same problem .
I can control my devices but this RED Led is not something i saw before .
I have the VeraLite almost a year Using UI5 and i did upgraded the Firmware to 1.5.672 when i added the new devices
Maybe the firmware update causing all this (i got the firmware link from the MCV Support)??
Did these issues occur before you added the new devices and did the firmware upgrade?
If no, try removing the newly added devices and reboot your Vera. If the problems go away, one or more of the devices you added is causing the issue. Try adding one device at a time (eg one per day) and if the problems return, it’s most likley the last added device.
If re-adding the devices does not bring relief, do you really need that firmware upgrade?
If no, Roll Vera back to the previous firmware and see if the issues go away. If so, the new firmware was the problem.
If yes, then I’m out of suggestions.
For future reference, in the IT world, the last thing you want to do is make hardware changes and perform firmware updates at roughly the same time. As it will be hard to pinpoint the cause of issues that way.
If none of the above work, I would strongly suggest to contact Vera Support and have them investigate.
