My local WiFi setup: A Comcast router (10.1.10.1) provides DHCP internal IP addresses (starting at 10.1.10.40). I have an AirPort Base Station (10.1.10.2) providing the wifi. There are 2 Airport Expresses (.3 and .4, in Bridge Mode) extending the wireless signal.
My personal desktop has a static IP below the DHCP pool range. It is configured as “Using DHCP with manual address,” and manual address is 10.1.10.9. The “router” (gateway) field is set to 10.1.10.1 (which correctly points to the Comcast router).
I set up my Vera Plus pretty effortlessly. The Net & WiFi setings were on “Automatically configure.” It got a DHCP address from the router: 10.1.10.50. All works well.
The next time I rebooted my desktop, some weird things started happening. I could no longer VNC to that machine from the outside world, which I would do regularly. That was the tip-off. I double-checked my desktop IP address: still 10.1.10.9.
Then I noticed that under the “Router” (gateway) settings, it now said 10.1.10.50 (the address of Vera)!
Initially, I didn’t realize that Vera was not only capable of connecting to WiFi, but was also providing WiFi. I certainly don’t need that functionality, so I switched Vera to “Manual” network mode, and turned off the WiFi providing. (“WiFi on” => “no”). I have “DHCP Server”=>“off”. Under “What Network Connection Type do you have?” I have “DHCP” selected, and it reflects the address 10.1.10.50, and the gateway as 10.1.10.1 (as it should be).
Given those settings, why in the hell would my desktop machine automatically think that 10.1.10.50 is my gateway? This happens across reboots. It ignores the 10.1.10.1 machine (which SHOULD be the only DHCP server in the area), and goes straight to the Vera’s IP address.
To make matters worse, on rebooting my Airport Expresses, one of them followed suit, claiming 10.1.10.50 as its gateway. It’s as if the Vera insists on being the alpha gateway of the pack.
I’ve had to drop the “Using DCHP…” notion, and switched to full manual mode, and that’s been OK.
But clearly the Vera seems to be broadcasting some sort of “Hey, I’m a internet gateway!” signal that it shouldn’t be.
Any ideas on running this down?
