Hi folks!
I was hoping for some insight and to see if anyone else is having issues with the 1.7.2414 firmware. This is my 3rd Vera device. In September, I started with a clean slate and a new Vera Plus. I manually added all my devices and recreated all my PLEG logic. The setup was rock solid until I upgraded to 1.7.2414. I’m not sure if it’s firmware related or coincidental.
I have the following apps: PLEG, PLC, VeraAlerts, GE Caddx, Nest, Netatmo, MIMOlite, MulitSwitch, and Day or Night
The logs seem to rotate every 10-20 minutes, which seems a bit fast. I see this in the logs with about the same frequency:
“LuaUPnP Terminated with Exit Code: 245” and “LuaUPnP crash”
I’ve been dealing with Jack E. at Vera who’s been very nice. At first he thought the unit looked OK, then thought some Dahua cameras were causing the issue: “Apparently your Dahua cameras are flooding the network and this is why the Vera unit is rebooting so often.”
I tried disabling “Auto detect devices on my home network” which seemed to cut some outbound requests Vera was making to those cameras, but was informed that " the issue is directly related to the Dahua cameras." I’ve since removed the cameras from my network, but the Vera Plus still seems to be having the same issues. I’m awaiting further help from Vera, but so far, we haven’t been able to figure anything out.
Since it’s rebooting so often, much of my PLEG logic gets messed up because of state issues. Most automation becomes fairly useless and the setup is nothing more than a complex remote control. I’ve tried a factory restore and reloading a backup from the days of stability, but that hasn’t helped. Also, I was informed that firmware downgrades aren’t supported on the Plus.
I haven’t had the time to do any network inspection, but I fear I’m going to have to in the near future. Anyone else with similar problems or have any insight? My couple months of automation bliss have turned to frustration.
Many thanks!
