HAd some issues with a device and the solution from vera support was to update, that caused some more problems. After about 2 weeks of troubleshooting , all is working again.
I asked vera support how my vera plus looked like , am I maxed out , is there room for more?
This is the answer:
I have double check a brand new controller ( Vera Plus ) that we have in our office and here is the space left on the overlay partition ( which is the one that is most important, when we take about space ) and here is the output:
/dev/mtdblock7 8.6M 3.4M 5.2M 39% /overlay
and for your unit it is:
/dev/mtdblock7 8.6M 6.8M 1.9M 78% /overlay
I am not sure if that is bad , acceptable , or good enough… anyone can share some light?
The other thing ( why I am posting in the datamine directory:
Support noticed that the datamine directory on my vera plus is quite/too large ( see attachment). It is full of backups. Is that normall?. Why are they stored there? did I do something wrong? Can I delete them?
I cannot directly answer your question but I tend to use the System Monitor plug-in to keep an eye on memory. When I used to use Datamine2, I would track about 3 memory parameters so some information is in System Monitor, if you use something like PLEG to harvest it. I am a Noob at using Linux commands to get the information Customer Care provided to you.
@ Don Phillips: I use system monitor plugin as well, but that doesn’t show the free disk space, only the free memory available. Customer care said :“the space left on the overlay partition ( which is the one that is most important, when we talk about space”.
Your datamine isn’t mounted in the overlayfs. With 6 gigs you shouldn’t have any issue.
To reduce space in /overlay you need the directories it uses like where all you plugins are installed like etc-ludl.
When you upgrade next you’ll want to make sure you are cleaned up in overlay.
Directories on the Vera are mounted or linked to overlay but etc-cmh is another on and there’s some firmware directory storing old firmwares that can be deleted to save space.
Sent from my VS995 using Tapatalk
