I’ve Vera Plus controller and i wonder is it support z-wave devices that use the 916MHZ (Israel standard) and EU MHZ together?
THX
THX
No, the unit cannot use two different frequencies.
Is there a USB stick available in 916?
He could disable the internal radio and use his USB stick.
But then you still can’t have two frequencies at once
My bad, I glanced over the 2 together, however, perhaps 2 Vera’s could be used each on the required frequency and bridged? Just should point out that this could be illegal in certain regions.
