Good Afternoon All,
I have a Vera Plus with ~35 powered switches (all Zwave Plus) ~8 battery operated devices (all zwave plus). Yesterday I installed a Fibaro smart plug for the following use case:
- When my wife works in her office I use an OR funciton in REACTOR to detect presence from either a motion detector or the enrgy reading from the smart plug which has her computer monitor plugged into it.
Since installing the smart plug I have noticed that the VERA Plus will start to slow down and freeze up after about 6 hours and the motion sensors become unresponsive. I am still able to use the UI7 interface, however, changing the state of a switch in the interface will not yield any actual result.
Rebooting appears to be the only solution that fixes the issue (for a short time).
Additional Notes:
- I have reduced all the update periods for my battery devices from the default 2 hours to 12 or 24.
- I have disabled some reports from the 4 Fibaro motion sensors I have.
- I run a scheduled reboot every day at 5am
I have attached a log file since my last reboot for reference. Gofile - Free Unlimited File Sharing and Storage
Thanks in advance for your help and suggestions:
Phil
