Hi everyone,
I am having trouble downgrading the Vera plus firmware.
Basically I have been using the Custom URL Download:
I got the URLS from the forum and have tried multiple versions. I am trying to get a firmware older than april 2017 in the Vera plus.
I tried this (obtained from the forum):
http://dl.mios.com/firmware/mt7621/mios/release/mt7621_Luup_ui7-1.7.2044-en-mios.squashfs
and
http://dl.mios.com/firmware/mt7621/mios/release/mt7621_Luup_ui7-1.7.2138-en-mios.squashfs
and
http://dl.mios.com/firmware/mt7621/mios/release/mt7621_Luup_ui7-1.7.2608-en-mios.squashfs
The thing is, every time I do the downgrade the Vera Plus for some reason reboots and reverts to version 1.7.3532. Which is the firmware that came from the factory. I even tried upgrading the vera plus to the latest 1.7.3831 and then downgrading using one of the above links, yet still after that process the vera goes back to 1.7.3532. I am doing this on 2 Vera Plus’s and I am getting the same results.
What is going on why cant I downgrade them. I was doing this with multiple vera edges before and it worked perfectly.
Any insight? Thank you.
