My Vera Plus has been working very well for the past year or so. A few times scenes would not run and a reboot usually fixed the problem. I went to change the time for a scene and noticed it will not save any changes. Also, I tried to delete the scene and create a duplicate and that didn’t work either. It did let me back up the Z-Wave Network and backup the system.
Anyone have any ideas? Thanks for looking at this.
Check the time zone in your location settings and then look at your network settings and make sure it didn’t somehow screw something up. Turn off WiFi if you don’t use it.
You could reboot your router too just in case.
Just a few ideas, not truly sure if that will help.
I checked the system date and it’s set to the wrong time zone. When I try to change the time zone through it’s IP address it says “Failed to change location data you are not authenticated.” I can logon through the home.getvera.com but it says my controller is offline. My WiFi is definitely working. I noticed all of the LEDs on the Vera Plus are on steady. Any ideas.
Sounds like your NAND Flash ran out of space…
The symptom in that case is indeed that the vera is unable to write and update anything in any file. If you need more space for your setup, you could consider extrooting the vera with an external SSD.
[quote=“rafale77, post:8, topic:200430”]Sounds like your NAND Flash ran out of space…
The symptom in that case is indeed that the vera is unable to write and update anything in any file. If you need more space for your setup, you could consider extrooting the vera with an external SSD.[/quote]
Hey, I know a guy who knows how to fix that!
