I have read through all I can of the Denon threads here. I cannot find an answer to this. I have tried to install the Denon Plug In from the Install Apps tab. It did not work, and all I can see is this error:
System error : Device: 30. Fail to load implementation file D_Codeset_1103.xml.lzo
System error : Device: 32. Fail to load implementation file D_Codeset_1103.xml.lzo
These came up after I tried to install.
For grins, I tried to install the Onkyo, and although I do not have an Onkyo receiver to test, at least the device showed up. The Denon does not show up as a device, just the above eror…
Help?
here is the log from the surrounding timeframe (bootup)
03/17/17 14:12:45.614 UserData::LoadUserData BuildVersion: 1.7.2608 SvnVersion: 18292 Model: 36 Sercomm G450 flush: 0 changed: 0 resync: 10004 syncdevice:1 <0x7743e320>
01 03/17/17 14:12:45.707 Device_LuaUPnP::LoadDeviceDoc can’t load /etc/cmh-lu//D_Codeset_1103.xml.lzo <0x7743e320>
02 03/17/17 14:12:45.708 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_Codeset_1103.xml.lzo <0x7743e320>
01 03/17/17 14:12:45.708 JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 30/D_Codeset_1103.xml.lzo so device 30 is offline <0x7743e320>
01 03/17/17 14:12:45.713 Device_LuaUPnP::LoadDeviceDoc can’t load /etc/cmh-lu//D_Codeset_1103.xml.lzo <0x7743e320>
02 03/17/17 14:12:45.713 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_Codeset_1103.xml.lzo <0x7743e320>
01 03/17/17 14:12:45.713 JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 32/D_Codeset_1103.xml.lzo so device 32 is offline <0x7743e320>
01 03/17/17 14:12:45.717 Device_LuaUPnP::LoadDeviceDoc can’t load /etc/cmh-lu//D_Codeset_1103.xml.lzo <0x7743e320>
02 03/17/17 14:12:45.717 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_Codeset_1103.xml.lzo <0x7743e320>
01 03/17/17 14:12:45.718 JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 36/D_Codeset_1103.xml.lzo so device 36 is offline <0x7743e320>
02 03/17/17 14:12:45.756 Device_LuaUPnP::CreateServices device 4 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.771 Device_LuaUPnP::CreateServices device 5 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.792 Device_LuaUPnP::CreateServices device 6 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.793 Device_LuaUPnP::CreateServices device 7 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.794 Device_LuaUPnP::CreateServices device 8 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.795 Device_LuaUPnP::CreateServices device 9 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.831 Device_LuaUPnP::CreateServices device 10 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.832 Device_LuaUPnP::CreateServices device 11 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.833 Device_LuaUPnP::CreateServices device 12 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.837 Device_LuaUPnP::CreateServices device 13 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.838 Device_LuaUPnP::CreateServices device 14 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.883 Device_LuaUPnP::CreateServices device 15 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.887 Device_LuaUPnP::CreateServices device 16 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.893 Device_LuaUPnP::CreateServices device 17 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.894 Device_LuaUPnP::CreateServices device 18 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.895 Device_LuaUPnP::CreateServices device 19 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.896 Device_LuaUPnP::CreateServices device 20 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.897 Device_LuaUPnP::CreateServices device 21 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.898 Device_LuaUPnP::CreateServices device 22 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.900 Device_LuaUPnP::CreateServices device 23 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.901 Device_LuaUPnP::CreateServices device 24 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.903 Device_LuaUPnP::CreateServices device 25 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.904 Device_LuaUPnP::CreateServices device 26 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.905 Device_LuaUPnP::CreateServices device 27 doesn’t have interface, using topmost device interface <0x7743e320>
02 03/17/17 14:12:45.905 Device_LuaUPnP::CreateServices device 28 doesn’t have interface, using topmost device interface <0x7743e320>
01 03/17/17 14:12:45.912 Device_LuaUPnP::CreateServices Aborting device 30 because the topmost device has no interface <0x7743e320>
01 03/17/17 14:12:45.912 JobHandler_LuaUPnP::CreateAllServices failed to create 30 <0x7743e320>
01 03/17/17 14:12:45.926 Device_LuaUPnP::CreateServices Aborting device 32 because the topmost device has no interface <0x7743e320>
01 03/17/17 14:12:45.927 JobHandler_LuaUPnP::CreateAllServices failed to create 32 <0x7743e320>
02 03/17/17 14:12:45.927 Device_LuaUPnP::CreateServices device 33 doesn’t have interface, using topmost device interface <0x7743e320>
01 03/17/17 14:12:45.938 Device_LuaUPnP::CreateServices Aborting device 36 because the topmost device has no interface <0x7743e320>
01 03/17/17 14:12:45.939 JobHandler_LuaUPnP::CreateAllServices failed to create 36 <0x7743e320>
01 03/17/17 14:12:46.064 UPnPAction_Send::ParseState can’t find name <0x7743e320>
02 03/17/17 14:12:46.066 Device_Basic::m_eConfigured_set device 1 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.067 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZigbeeDevice1 <0x7743e320>
02 03/17/17 14:12:46.067 Device_Basic::m_eConfigured_set device 2 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.068 Device_Basic::m_eConfigured_set device 3 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.068 Device_Basic::m_eConfigured_set device 4 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.069 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.069 Device_Basic::m_eConfigured_set device 5 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.071 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.071 Device_Basic::m_eConfigured_set device 6 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.072 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.072 Device_Basic::m_eConfigured_set device 7 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.073 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.074 Device_Basic::m_eConfigured_set device 8 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.075 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.075 Device_Basic::m_eConfigured_set device 9 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.076 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.076 Device_Basic::m_eConfigured_set device 10 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.078 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.078 Device_Basic::m_eConfigured_set device 11 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.079 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.079 Device_Basic::m_eConfigured_set device 12 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.080 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.081 Device_Basic::m_eConfigured_set device 13 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.089 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.090 Device_Basic::m_eConfigured_set device 14 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.090 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.090 Device_Basic::m_eConfigured_set device 15 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.091 Device_Basic::m_eConfigured_set device 16 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.092 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.092 Device_Basic::m_eConfigured_set device 17 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.093 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.094 Device_Basic::m_eConfigured_set device 18 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.095 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.095 Device_Basic::m_eConfigured_set device 19 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.096 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.097 Device_Basic::m_eConfigured_set device 20 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.098 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.098 Device_Basic::m_eConfigured_set device 21 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.100 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.100 Device_Basic::m_eConfigured_set device 22 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.102 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.102 Device_Basic::m_eConfigured_set device 23 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.104 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.104 Device_Basic::m_eConfigured_set device 24 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.105 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.105 Device_Basic::m_eConfigured_set device 25 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.106 Device_Basic::m_eConfigured_set device 26 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.106 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x7743e320>
02 03/17/17 14:12:46.106 Device_Basic::m_eConfigured_set device 27 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.107 Device_Basic::m_eConfigured_set device 28 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.107 Device_Basic::m_eConfigured_set device 29 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.107 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:IrDevice1 <0x7743e320>
02 03/17/17 14:12:46.108 Device_Basic::m_eConfigured_set device 30 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.108 Device_Basic::m_eConfigured_set device 31 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.108 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:IrDevice1 <0x7743e320>
02 03/17/17 14:12:46.109 Device_Basic::m_eConfigured_set device 32 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.110 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZigbeeDevice1 <0x7743e320>
02 03/17/17 14:12:46.111 Device_Basic::m_eConfigured_set device 33 was 0 now 1 startup <0x7743e320>
02 03/17/17 14:12:46.111 Device_Basic::m_eConfigured_set device 34 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.111 Device_Basic::m_eConfigured_set device 35 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.111 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:IrDevice1 <0x7743e320>
02 03/17/17 14:12:46.111 Device_Basic::m_eConfigured_set device 36 was 0 now 0 startup <0x7743e320>
02 03/17/17 14:12:46.112 Device_Basic::m_eConfigured_set device 37 was 0 now 0 startup <0x7743e320>
01 03/17/17 14:12:46.113 Device_LuaUPnP::CreateImplementations Aborting 30 because it failed to load <0x7743e320>
01 03/17/17 14:12:46.114 JobHandler_LuaUPnP::CreateAllImplementations failed to create 30 <0x7743e320>
01 03/17/17 14:12:46.114 Device_LuaUPnP::CreateImplementations Aborting 32 because it failed to load <0x7743e320>
01 03/17/17 14:12:46.114 JobHandler_LuaUPnP::CreateAllImplementations failed to create 32 <0x7743e320>
01 03/17/17 14:12:46.114 Device_LuaUPnP::CreateImplementations Aborting 36 because it failed to load <0x7743e320>
01 03/17/17 14:12:46.115 JobHandler_LuaUPnP::CreateAllImplementations failed to create 36 <0x7743e320>
