When I set up my Vera Plus at our secondary home in Arizona, I was prompted to select a time zone and noticed that Vera had not only a Mountain Time Zone but an Arizona Time Zone. For those who don’t know, Arizona doesn’t use daylight savings time, so in the winter the state it is on the same time as the rest of Mountain Standard Time (one hour different from Central Standard Time where my primary residence is). However, when the country switches to daylight savings time, Arizona doesn’t, basically putting it on Pacific Daylight Savings Time or just Mountain Standard Time when the rest of that time zone is on Mountain Daylight Savings Time (that places Arizona two hours different from Central Daylight Time). So I anticipated that the Arizona Time Zone would take this into account, but it didn’t seem to. My Vera control lights were coming on and going off an hour earlier than expected while we were there for 2 weeks in the middle of March (after the country had switched to daylight savings time) So I switched the time zone in the set up menu to Pacific Daylight Savings Time and will then need to switch it back to MST when we fall back from daylight savings time. Has anyone else experienced this? And shouldn’t Vera be able to take care of this bug in their time zone system? Maybe I am expecting too much. Thanks for any help out there.
I would suggest to email this to support@getvera.com as the fix should be an easy one and be incorporated in a new firmware.
BTW, you lucky dog, I wish Florida would get smart and get rid of EDT as well…
I apparently jumped gun on this one, as I switched my settings this morning to Arizona Mountain Time Zone and it maintained the two hour difference between CDT and MST. So maybe Vera fixed it or maybe I hallucinated it ( but I swear my lights were turning on an hour early when we were there on late March after daylight savings time had gone into effect).
