Why the Vera app is no longer in Apple Watch? How can I operate Vera via Apple Watch?
Ezlo pulled the app as it’s not compatible with the current WatchOS it seems. In the meantime, you can control scene’s from the Apple Watch using shortcuts. Set up a shortcut on your iPhone, select Vera as App and you can select scene’s.
This shortcut should then be available on your watch as well. Nice thing is, these shortcuts can be controlled by Siri as well. So now you have the option to run Vera scenes by using Siri on your watch.
It’s not very fast, jumping through several hoops (Siri -> shortcuts -> iPhone -> Vera App -> Vera cloud -> Vera controller -> device) before any action takes place. But it works!
Thanks. Interesting when Vera app will work again via Apple Watch.
