I have the same problem, but the suggested string did not produce the expected result.
Reactor 3.7
On the Expressions screen I define an empty variable: DevLoc=
On the Activities screen I assign the variable in conditions: Set Variable DevLoc = Back
On the Status screen I see the Expression: DevLoc (no expression) “Back”
On Activities I send the alert: Notify Vera-native {DevLoc + " Door is open"}
The text messages says: ({DevLoc + " Door is open"} Door Open Alert in Locks)…
I re-read your message and saw you are not, in fact, using VeraAlerts (the thread you posted in is for VeraAlerts alerts, so I started a new thread for your message).
The native Vera notifications do not support variable substitutions. You can check the docs to see which other notifications you might be able to use.
Thanks Rigpapa. I didn’t realize the difference between Vera-native and VeraAlerts. I’ve read the VeraAlert docs. That is a whole different rabbit hole to go down. I’ll check it out. Thanks again.
After re-thinking, I simplified my logic. I have a compound OR logic which separately checks for the Front Door or Back door tripped for longer than 60 seconds with a 15 minute NOT AND interval to re-notify. At first I had the alert being sent from the root group and assigning a variable from each of the subgroups to identify which door was open. I removed that notification and configured separate notifications from each subgroup. One for Front and one for Back. It’s working and I didn’t need to add VeraAlerts (yet). That will come in time. I’m just trying to understand how much Reactor can do first.
