Vera Plus module is connected to SONOFF Zigbee BASICZBR3 DIY.
Pairing and work is good, but there is no button in the mobile app ON.
http://piccy.info/view3/13970721/c2d9ffd48fc79ea2fa878c0614df6aaa/
Android 10. MiMix2S
Android 10. MiMix2S
Is the ON button also missing in the Vera UI7 website interface?
Can you go in to the device then Advanced then on the Params tab, what are the following values for these items?
device_type
device_file
impl_file
device_json
category_num
subcategory_num
device_type - urn:schemas-micasaverde-com:device:GenericIO:1
device_file - D_GenericIO1.xml
impl_file - empty
device_json - D_GenericIO1.json
category_num - 11
subcategory_num - 0
Try changing them to the following values.
device_type
urn:schemas-upnp-org:device:BinaryLight:1
device_file
D_BinaryLight1.xml
impl_file - empty
device_json
D_BinaryLight1.json
category_num
3
subcategory_num
1
And reload the Luup engine.
Thank!
The lamp has a socket icon and a switch is working
The Sonoff Zigbee ZBmini works with Vera Plus!
It was a very strange installation as it refused to stabilize for several hours(continuously configuring), and then suddenly it started to work flawlessly. I had basically given up on all attempts by then!
The icon is a socket icon, not a lamp. Maybe it can be changed?
