Vera Lite Newbie - How to use the Sonos Plugin
Hey Guys
So ive recently got my Vera Lite and its controlling me lights etc without a problem. The other day I went ahead and installed the Sonos plugin without a problem, but right now im having trouble understanding how to actually use it. Ive followed and read the usual guide here: Sonos Wireless HiFi Music Systems but no matter what I do I cannot get the plugin to play music out of one of my play lists.
So far ive managed to get it a track, however I had to select the track from my Sonos app on my iphone.
So as an example within the plugin I select Playlist from the URI menu and then type SQ:R&B being my play list is called R&B. I adjust the volume to 30, and hit play but I get nothing.
Any of you guys have an idea of what im doing wrong?
Please try a playlist without a & in the name.
I am almost certain I already fixed this issue in the version in development. I will check this evening.
Furthermore, I will have to check if “SQ:R&B” is working in the scene editor (advanced tab). I am not sure if the scene editor is escaping the &
If you select “Sonos playlist” in the picklist, you must enter only the name of your playlist in the next field, that is R&B.
If you select nothing in the picklist, you must enter SQ:R&B in the next field.
With the current version in trunk, I tested with a playlist named “R&B”. It is working perfectly, either froml the UI or from a scene.
… My main reason for being so interested in the Sonos Plugin was the TTS feature…
No i’m hooked… but here is what may be a basic question but I can’t find the answer:
How do I determine the URI of a track or XM radio station?
I haven’t played with this much, so would be curious about a more authoritative answer. One thing I’ve done was to mark a radio station as a Sonos favorite. After that the help tab told me to used “FR:____” to access it
[quote=“jimpapa, post:4, topic:179232”]… My main reason for being so interested in the Sonos Plugin was the TTS feature…
How do I determine the URI of a track or XM radio station?[/quote]
Take a look at the Help tab that displays examples of URI to be used + current URI when something is being played…
For a track in your media library, play it and then check its URI in the Help tab. It should be something starting with x-cifs-file://…
For a radio, it depends on the used service.
For a standard WEB radio, just replace http with x-rincon-mp3radio in the URL of the WEB radio.
For TuneIn and Sirius services providing radio, I have implemented something special. You have an identifier to extract from the URI displayed in the Help tab.
For other services, you can get the URI from the Help tab but it will probably not work.
What is XM service ?
If you provide the values of the 4 variables (2 URI and 2 metadata) displayed in the Help tab, I can try to study what I can do for you.
XM is the SiriusXM satellite radio stream
OK… Got it… Help Tab to get the URI works great!
For Sirius radio, this topic is probably interesting: http://forum.micasaverde.com/index.php/topic,13612.0.html
