Is this possible and if the answer is “yes” what i need to do?
I saw other posts, but…
Thank you in advance
I cannot remember the CM15pro was compatible but the two threads are where you should go looking.
I tried to use CM11 install, but the result is:
“If you connected the USB/serial device and it’s not displayed here, reload Luup.
Not available.”
I gave up trying to get the cm15pro working through USB direct to Vera.
I got the connection going using mochad running on a raspberry pi which works a treat, but then I had a pi on my network to start with, though it now has it’s ow dedicated (very underused as a result) pi.
