Vera LAN IP what is this? 192.168.81.1
Hi
I gave VeraLite a static IP on my local LAN subnet is 192.168.0.X
I can see a LAN IP option which is currently set to 192.168.81.1 what is this for and should I change it?
[quote=“cw-kid, post:1, topic:172404”]Hi
Thanks[/quote]
That is for when you directly connect your pc to the VERA via an ethernet cable.
OK great, so I don’t need to do that so I don’t need to change this IP then…
Thanks.
