Hello,
I am interested in buying the Vera Plus hub to control multiple Power relays, However, I would like to know if their are 8 Channel relays available in the market that could be controlled with the Vera Hub.
Have approximately 8 different switch locations at home and each location consists from 6 to 12 light switches that I would like to control remotely.
your Advice is highly appreciated. I have tested the relays controlling them via arduino however it is too complicated and time consuming as also my skills with programming https are not supporting.
Regards,
