root@MiOS_$$$$$$$$:/# block mount
block: mounting /dev/mtdblock6 (squashfs) as /mnt/mtdblock6 failed (-1) - Unknown error -1
block: /dev/mtdblock9 is already mounted
block: /dev/sda1 is already mounted
block: /dev/sda2 is already mounted
So it’s mounted. Have you run the extroot script?
C
about 13 times …still the same thing
Filesystem Size Used Available Use% Mounted on
rootfs 8.6M 5.1M 3.6M 59% /
/dev/root 10.0M 10.0M 0 100% /rom
tmpfs 124.8M 416.0K 124.3M 0% /tmp
/dev/mtdblock7 8.6M 5.1M 3.6M 59% /overlay
overlayfs:/overlay 8.6M 5.1M 3.6M 59% /
tmpfs 512.0K 0 512.0K 0% /dev
/dev/sda1 493.6M 2.6M 454.7M 1% /tmp/log/cmh
/dev/sda2 109.4G 104.8M 103.7G 0% /mnt/sda2
/dev/mtdblock10 50.0M 1.4M 48.6M 3% /storage
/dev/mtdblock10 50.0M 1.4M 48.6M 3% /etc/cmh-firmware
/dev/mtdblock10 50.0M 1.4M 48.6M 3% /etc/cmh-backup
/dev/mtdblock9 9.8M 9.8M 0 100% /mios
root@MiOS_#######:/# ls /dev
batM0 loop5 mtd4 mtdblock2 root
bus loop6 mtd4ro mtdblock3 sc_gpio_ioctl
button0 loop7 mtd5 mtdblock4 sc_led_ioctl
console mem mtd5ro mtdblock5 sda
cpu_dma_latency mtd0 mtd6 mtdblock6 sda1
full mtd0ro mtd6ro mtdblock7 sda2
i2cM0 mtd1 mtd7 mtdblock8 sg0
i2s0 mtd10 mtd7ro mtdblock9 shm
kmsg mtd10ro mtd8 network_latency tty
log mtd11 mtd8ro network_throughput ttyS0
loop-control mtd11ro mtd9 null ttyS1
loop0 mtd1ro mtd9ro port ttyS2
loop1 mtd2 mtdblock0 ppp urandom
loop2 mtd2ro mtdblock1 ptmx watchdog
loop3 mtd3 mtdblock10 pts zero
loop4 mtd3ro mtdblock11 random
Hold on and take a deep breath here. Did you get any error during the process?
If no, and it is likely, it looks like your rootfs was correctly copied over to your SSD (/dev/sda2)
So you are good. The only problem is that the system appears not to have pivoted properly during boot up. Can you please go look into your /cmh/config/fstab and make sure that it is setup correctly?
>config global
option anon_swap '0'
option anon_mount '1'
option auto_swap '1'
option auto_mount '1'
option delay_root '5'
option check_fs '0'
config swap
option enabled '0'
option device '/dev/sda2'
config mount
option enabled '1'
option target '/'
option fstype 'ext4'
option options 'rw,sync'
option enabled_fsck '0'
config mount
option enabled '1'
option target '/tmp/log/cmh'
option fstype 'ext3'
option options 'rw,noatime,nodiratime,errors=continue,data=ordered'
option enabled_fdisk '1'
option enabled_mkfs '1'
option enabled_fsck '1'
option label 'mios'
option fssize '512'
option fsck_days '30'
option fsck_mounts '10'
option device '/dev/sda1'
config mount
option target '/mnt/mmcblk*'
option enabled '1'
is that from root or from etc/config/fstab ?
config global
option check_fs '0'
config mount
option label 'mios'
option fssize '512'
option target '/'
option enabled '1'
config mount
option enabled '1'
option label 'mios'
option fssize '512'
config mount
option enabled '1'
config global 'automount'
option from_fstab '0'
option anon_mount '0'
config global 'autoswap'
config mount
config swap
option enabled '0'
config mount
config swap
config mount
config swap
config mount
config swap
config mount
config mount
config mount
no errors that i am aware of
Yes it looks good. I noticed that the pivot can fail at times mostly due to timing of when the SSD is available. It may take sometime for the USB interface/SSD to be ready.
I also noticed at one point that the pivoting may be forced using uuid instead of the device path. Is your SSD on a powered USB hub?
I attached a slightly updated script which uses the uuid of the drive instead of the /dev path. Code change courtesy of @DesT. It should help with the pivot timing.
extroot.sh.zip (1.5 KB)
ok i will try this
rootfs 8.6M 5.0M 3.6M 58% /
tmpfs 124.8M 332.0K 124.4M 0% /tmp
/dev/mtdblock7 8.6M 5.0M 3.6M 58% /overlay
overlayfs:/overlay 8.6M 5.0M 3.6M 58% /
/dev/sda1 493.6M 428.0K 456.9M 0% /tmp/log/cmh
/dev/sda2 109.4G 104.6M 103.7G 0% /mnt/sda2
mouting it but not doing the pivot
cfg094d78
cfg0a4d78
/dev/mtdblock6: UUID="7da747e6-4ed89c8d-0dc86410-f064d4b6" VERSION="1024.0" TYPE="squashfs"
/dev/mtdblock7: TYPE="jffs2"
/dev/mtdblock9: UUID="c82ec6c0-834b904c-3543ccdc-032a1b86" VERSION="1024.0" TYPE="squashfs"
/dev/sda1: UUID="1ec55429-6c3a-4a6a-99a3-4198f7c4c8bf" LABEL="MiOS" NAME="EXT_JOURNAL" VERSION="1.0" TYPE="ex t3"
/dev/sda2: UUID="f931ca64-b956-45d8-b539-1e4c1b7f3993" NAME="EXT_JOURNAL" VERSION="1.0" TYPE="ext4"
@richie.digital
add this two line in the /etc/rc.local (before exit
export PREINIT=1
mount_root
what would that do?
nope didnt work
You, I hope, only added the two lines and did not copy the fstab example but if you did, you replaced the uuid with yours right?
It seems a lot like you have some mount timing issue. I have at times experienced the failure of the pivot but it’s always been because the SSD was ready too late in the process. It could be because of a slow hub or a slow USB/SATA interface.
Having the SSD powered on before the vera (using a powered hub) and using the uuid both helped.
but it worked absolutely ok up until the veraPlus crashed, but i can try that but the ssd is powered by the usb port
When it happened to me, the problem was intermittent… it is a hardware timing issue. Every few reboots, it would fail to pivot. @DesT saw the same thing and I gave him the same uuid suggestion which appeared to have worked for him. You either have had some hardware degradation or you just got “lucky” initially.
nope same thing ------ im gonna pull the drive and zero it out
usinf your fstab i get
block: extroot: failed to load /etc/config/fstab: Parse error (invalid command) at line 2, byte 0
got it mounted but still cannot extroot
in other news whe i run the commands individually i get
root@MiOS_######:~# mkfs.ext4 /dev/sda2
mke2fs 1.42.4 (12-June-2012)
/dev/sda2 is mounted; will not make a filesystem here!
mount /dev/sda2 /mnt/sda2
mount: mounting /dev/sda2 on /mnt/sda2 failed: Device or resource busy
root@MiOS_#######:~# fdisk -l
Disk /dev/mtdblock0: 127.5 MiB, 133693440 bytes, 261120 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/mtdblock1: 512 KiB, 524288 bytes, 1024 sectors
Disk /dev/mtdblock2: 512 KiB, 524288 bytes, 1024 sectors
Disk /dev/mtdblock3: 256 KiB, 262144 bytes, 512 sectors
Disk /dev/mtdblock4: 20 MiB, 20971520 bytes, 40960 sectors
Disk /dev/mtdblock5: 20 MiB, 20971520 bytes, 40960 sectors
Disk /dev/mtdblock6: 18.6 MiB, 19513856 bytes, 38113 sectors
Disk /dev/mtdblock7: 8.6 MiB, 9043968 bytes, 17664 sectors
Disk /dev/mtdblock8: 1 MiB, 1048576 bytes, 2048 sectors
Disk /dev/mtdblock9: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/mtdblock10: 50 MiB, 52428800 bytes, 102400 sectors
Disk /dev/mtdblock11: 19.3 MiB, 20185088 bytes, 39424 sectors
Disk /dev/sda: 111.8 GiB, 120034123264 bytes, 234441647 sectors
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sda1 * 1 1060289 530144+ 83 Linux
/dev/sda2 1060290 234436544 116688127+ 83 Linux
