Hi is it normal for Internet green led to be flashing? Changed router and it started doing this thanks
Hello @Harry123,
VeraEdge LED’s Operations
Your VeraEdge controller has five LED lights. The lights are Power, Internet, Wi-Fi, Z-Wave, and Service. Below, you will find the meaning of each LED state:
Power LED
- On - Power On/Normal Operation
- Off - Power Off
- Flashing - Booting/Firmware Upgrade
Internet LED
- On - Connected to the Ethernet
- Off - Not connected to Ethernet
- Flashing - Data is being transmitted or received via the Ethernet connection - Connected to the Ethernet
WiFi LED
- On - WiFi enabled
- Off - WiFi disabled
- Blinking - Traffic over WiFi
Z-Wave LED
- On - Z-Wave function enabled
- Off - Z-Wave function disabled
- Flashing slow - Include mode
- Flashing fast - Exclude mode
Service LED
- On - Cloud Service connected and working properly
- Off - No Cloud Service installed
- Flashing - Cloud Service is not sending data properly
VeraEdge Button Operation
Your VeraEdge controller has three buttons on the side which can be used to reset the unit, include or exclude Z-Wave devices, and pair networked devices over WPS.
Reset Button
The reset button requires a pin or paperclip to be pressed. It has two functions:
- To reset the network settings, hold the button for 5-10 seconds
- To reset it to factory defaults, hold the button for more than 20 seconds
If you changed the network provider, the controller may need a power cycle, network reset, or factory reset if it was connected using WiFi.
For further assistance, please reach out to support at support@ezlo.com
