hi
i buy a new veraedge system and test fibaro with vera but home center cant connect to zwave modules
anybody here has a experience about tkb modules
See [url=http://forum.micasaverde.com/index.php?topic=25132.0]http://forum.micasaverde.com/index.php?topic=25132.0[/url]
[quote=“craft, post:1, topic:191482”]hi
anybody here has a experience about tkb modules[/quote]
What TKB modules do you mean. I the TKB single and double paddle wall switches and dimmers. I also have one TKB dual relay module. All work perfectly, they all installed straight from the box and configured correctly. The only (in my opinion) disadvantage is that they do not support instant status.
I actually managed to get a number of single paddle switches cheap (?10.00 each) which I took the switch from and then used them as in wall controllers (watch your load if you do this). Overall, apart from the instant status they seem excellent.
[quote=“Slartibartfast, post:3, topic:191482”][quote=“craft, post:1, topic:191482”]hi
I actually managed to get a number of single paddle switches cheap (?10.00 each) which I took the switch from and then used them as in wall controllers (watch your load if you do this). Overall, apart from the instant status they seem excellent.[/quote]
I forgot to add that I originally had the Edge and now have the Plus. Did a clean install on both with no problems.
