Having problems pairing Vera Edge to the Schlage lock.
Using Vera Edge with latest firmware 1.7.2607
Spent all weekend trying to connect the ?Schlage BE469WK CAM 619? lock to my Vera Edge.
Vera edge is currently connected to three Z-Wave lamp module/repeaters #JASCO #45652 (Works Fine).
One of the repeaters (#45652) is 4 ft from the Schlage lock.
Factory reset the Schlage lock several times to try to pair in the different modes listed below.
Tried portable pairing by putting Vera unit next to door lock.
(VERA EDGE) No internet connected, Power Vera unit, wait for all LEDs lit, press sync, Z-wave LED flashing.
(Schlage BE469WK) Press “Schlage button”,enter 6-digit code, enter “0”
Results: “X” meaning lock did not connected.
Tried pairing thru Vera dashboard website with Vera Edge unit farther away from door lock (40 ft away )
Factory reset the Schlage lock.
(Vera Website) Device/Add Device/Door locks/Schlage SCH-TSBR-605C
Step# 2 of setup, programming 4?digit code for door lock.
Step# 3 of setup, Starts inclusion to Vera Edge
(Vera Website) Click retry, still not working.
The lock selection on website has only the Schlage SCH-TSBR-605C listed. My lock is Schlage BE469WK CAM 619. Are these 2 locks the same?
Information online indicate if I have problem connecting that I should exclusion my lock or unpair my lock ? I am unable to find information on how to exclusion or unpair the lock.
What am I doing wrong?
