Is there a way for me to get my security key (Network) that Vera edge would be using for secure comms, I am using node-red and the node requires this key I believe. The Network Key is a string of 16 bytes in hex format, separated by commas, "0xCA,0xFE,0xBA,0xBE,… " to use with secure zwave devices.
This is not documented and I had to open a ticket to get this information. I am hesitant to publish this since it is security related. I recommend opening a ticket or… can always PM me.
Rafale77 - Thank you. How can I pm you.
I’m having the same issue (trying to use Vera as Primary, OpenHAB as secondary), and also can’t really find how to PM you. Hm.
This is making me wonder if the answer should be published somewhere… I am hesitant to broadcast it but if the guys at ezlo are ok with it I will post it here.
I’d also like to know how the retrieve my vera network key. I’d guess through a backup dump or ssh
thank you!!! hexdump worked perfect
Sorry guys, I had to hide a few of these informations.
It’s better to be kept private or on a private development board.
we understand
