I have a vera edge. I set the wink to inclusion mode. I tell the vera edge to copy zwave network from primary controller. It says learning mode. Then establishing security. Then security failed. Then it says configuring devices but there are no devices after hours. How do I get this to work? Thanks.
You can’t get this to work…
The Wink Hub does not support controller shift…
