I have a Foscam FI8905W camera and I manually setup the camera on the VeraEdge UI7 OK. However the Foscam at the moment keeps resetting itself to factory defaults for some reason? And the static IP address and other settings I configured on the camera are lost. The camera then picks up a DHCP IP address from the router instead.
But Vera keeps on automatically installing the “Apexis IP Camera” plugin app when this happens and it then appears as a VistaCam. I am wondering if Vera itself is causing the Foscam to reset all the time somehow? As I never had this problem before with the Foscam resetting and back when I was using a VeraLite UI5.
