Vera Edge camera not streaming, only 1 image per second
I finally got my 3 Hikvision IP camera’s to work on my Vera Edge, by manual install.
But I do not get streaming video, the images refresh only once per second.
Did I miss a setting ?
No, vera does not stream the cameras in their native fps. Vera is not and will never be a camera security solution. It is only meant to view the current image or for streaming only few frames per second. Vera does not have the horse power to push out full streaming. You will need a NVR or software solution you can run on the computer for your cameras.
  • Garrett
Thanks for your explanation…
I use a Synology NAS and software, and DScam apps on my mobile devices, so that is covered.
[quote=“mtx123, post:3, topic:186627”]Thanks for your explanation…
I use a Synology NAS and software, and DScam apps on my mobile devices, so that is covered.[/quote]
Depending on what app you use for VERA, you can use that same app to direct Stream in that app along next to your vera devices.
For example I use ImperiHome. You add vera and you add the camera’s directly and you can intermix in the one app. I also use Virtual Motion sensor plugin in Vera to receive http commands from the DVR to trigger motion in vera for scenes or alerts or what ever.
I don’t add the picture to VERA due to the load.
