Vera doesn't update temperature from Everspring ST814 device
Dear all,
i got a new everspring ST814 detector (temperature and humidity) and i connectet with my VERA.
I associated everything and i’m able to watch in micasa interface the 2 windows with temperature and humidity that show temperature and humidity values.
The problems are:
  1. in micasa interface those values doesn’t chance even if in everspring there is a hance (temperature and humidity change)
  2. in micasa interface the temperature is shown in F and not in C even if everspring is set in C
i think there is some communication problem…
Someone can help me?
Thanks a lot.
For question 2: you need to set the temperature format in Setup → Location → temperature format.
  • Garrett
I’m not able to find in vera3 interface the following link: Setup → Location → temperature format
Where i should check?
About my question n.1 i realized that if i press 3 times the C/F/flashes bottom the dispositive will send the information to vera and the temperature will update also in vera interface.
So i think the issue is how to set this kind of communication (flash active) each some second or if there is a temperature/humidity variation…isn’t?
Are you sure you have a Vera 3 or Vera Lite ???
Temperatures are typically only updated when the device wakes up … and that is usually pretty long (Mine is 30 Minutes) in order to conserve the battery power.
Yes i have vera lite and i got the set-up to change F in C :slight_smile: (my mistake, so tired today :slight_smile: )
About the time to detect the change of temperature and humidity…i think it is not only a fact of wak up time because if i change it from 1800 sec to 10 sec (for example) there is not real time update…maybe i have to set Auto Report?
It won’t see your changes to interval until it wakes up!
To do what i needed i changed in DEVICE OPTION the values of the variable 7 and 8 (set to 1 and 5 respectively) leaving wake up time as default (1800 seconds).
Now if the temperature change of 1C or humidity change of 5% the information is send in real time to Vera3 interface.
