I am really concerned, my battery is drained, I checked and this is the reason, see PNG.
Are you running in LAN mode ?
On both, is my cellphone, I have a port specified for when I am at home and when not, receive via 3g
That will eat the power … it has to run ALL the time to listen on the port.
All your base are belong to us
Thanks Richard, I changed it to port 0 again. See how it works. Regards.
You cab use Tasker to change the port setting for you when you are home (on your LAN) or away.
Great idea! Thanx!
