Vera Concierge is now available for use.
This provided voice communications with your Vera using your Google Home or any mobile that supports Google Assistant.
For more details see the website:
http://VeraConcierge.com
You can use the Vera Concierge to access multiple Veras, locally or remotely connected.
Not only can you use it command your devices … you can also use it to get the status of a particular device, or find out what is currently active in your house.
There is a forum board dedicated to this app:
See:
http://forum.micasaverde.com/index.php/board,88.0.html
