After adding device and Selecting User Account in Google Home App, “Linking your Vera Concierge Smart Home account”. A quick message at the bottom of the screen states “Couldn’t update the settings, check your network connection.”
If I look under “Explore” in the “Google Home” add, both “Vera Concierge Smart Home” and “Vera Concierge” show that they are linked
Each time I ask Google to turn on a particular light, the response is “It looks like those lights haven’t been setup yet”, sends me back to Google Home. Google Home states “Link smart home devices”, when I click “LINK DEVICES NOW”, it puts me back into “Home control”, if I click the + to add, I’m right back where I started.
[quote=“RichardTSchaefer, post:14, topic:198382”]Which google App update ?
It’s working for me … and I am using the commercial version.[/quote]
When I used the home control app listed under Home control (the new one google approved) versus using explore to use Vera… all things stopped working.
Now I did do a firmware update to my Vera Lite, so I’m not sure what happened but now nothing works.
When I unlinked and tried to link back up, only the google released VC app is listed under Home Control., but I thought that doesn’t work or should not be even listed.
I’m a little confused as to what should be going on.
My Concierge server all works and sees my google home,mini and chrome cast. It seems I can not link VERA under the app as it uses only the home control app 3.0
Without using aliases !!!
There are two Voice Interfaces:
1) Google Home → Home Control
Where devices are added using Vera Concierge Smart Home
OK Google Turn on the Office Light
2) Google Home -> Vera Concierge Assistant
OK Google Ask Vera Concierge to turn on the Office Light
The (2) one is down right now (all because they did not like an Icon I used) and I am in the process of getting it re-instated.
[quote=“RichardTSchaefer, post:18, topic:198382”]Without using aliases !!!
The (2) one is down right now (all because they did not like an Icon I used) and I am in the process of getting it reinstated.[/quote]
Hmmm, I have linked and unlinked option one and still doesn’t work. I did a firmware upgrade to the latest on my Vera Lite. I had to factory reset and restore from backup since there was a limitation on storage. I must have done something. My start LUA shows correctly as require Vera Concierge and Concierge Server lua file is there as well.
Another thing I noticed… the Concierge server web page under software does not list any software any longer. Is this supposed to be this way now?
